I have currently moved company, and my dims aren't working in the same way (also updated to 2012LT from 2010LT)
I want the dimension to display in integers, but I want the measurement in the quick properties to have a precision of 2 decimal places.
Now it was done at my last place, but I cannot find how to do it at my new place!!
Anyone know how to do this??
Solved by pendean. Go to Solution.
DIMSTYLE command and set your dimension style in use in the current file to any setting you desire, including precision.
UNITS command, use it in the current file to set the display precision to anything you want.
Notice these are per-drawing-file settings, there is no system wide option. And since you are at a new place of employment, ask around about why it's not set like that in all files and in their template files and see if it can be changed.
