If you explode the dimension, you can use the "Properties" tool button and
change the font size.
For new dimensions of a different font size, the format menu lets you choose
dimension style/annotation settings which will set the properties for all new
dimensions added to the drawing.
As far as changing the whole existing drawing dimension text size - I don't
know.
Hope this helps.
Don
HP Authorized Customer wrote:
> I'm having trouble changing the font sizes in dimensions. If I right-click
> on the dimension and use the editor, I can change the font but if I change
> the size setting (like, from 1' to 6") the font size remains the same.
> Any ideas on how to do it? Is it font-dependent? If so, what type of font
> do I need to use?
> Also, how do I change the font and size for the dimensions for the whole
> drawing?
> Thanks for your help.
