Changing the UCS affects all viewports I believe: are you trying to just
change the viewpoint in each viewport? Rotate a viewport and need to use the
PLAN command?
From HELP, rotate views using UCS:
To rotate a view by changing the UCS
1.. Make sure you are on a layout tab.
2.. Double-click in the viewport whose objects you want to rotate.
3.. Make sure that the current UCS is parallel to the plane of rotation
(the UCS icon should look normal). If the UCS is not parallel to the plane
of rotation, from the Tools menu, choose New UCS, and then choose View.
4.. From the Tools menu, choose New UCS, and then choose Z. To rotate the
view 90 degrees clockwise, enter 90. To rotate the view 90 degrees
counter-clockwise, enter -90.
5.. From the View menu, choose 3D Views, and then choose Plan View. Choose
current UCS.
The entire view rotates within the viewport. You may need to respecify the
scale of the viewport.
Also try this tutorial:
http://www.engr.panam.edu/~scrown/graphics/notes/lecture12.ppt
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
