When I dimension a diameter, ex....250 dia second line is csink .313 X 82 degrees, the .250 text is centered over the csink note. My boss wants both lines of text to be left justified and the leader to be centered between the 2 lines of text.
I use AutoCadLT2009. Is there any way of fixing the default to accomplish what needs to bne done? Right now I have to use Qleader and create a middle between the 2 lines of text and grip the land of the leader down to the area that is centered between both lines of text.
Thank you,
John Haase
Try QLEADER - Settings - attachment - Text on left side and Text on right side - set to "Middle of multi-line text"
