How can I, or can I apply a specific layer to a specific command?? When I choose the dimension command, i want it to automatically become my "Dim 1" layer without having to select it, then select the layer. Is this possible??
Thanks in advance.
Solved by Charles_Shade. Go to Solution.
Yes you can!
From the CUI add: -la;_Make;your layer; to a Command*
Example:
^C^C-la;_make;Dim;; (Italics for emphasis only)
Please remember to check Solved if your question has been answered
*Some tweaking may be required
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I used to have a button macro for drawing wiring, that would cancel all else, change to the wire layer, and draw a 3 point arc before repeating. It even snapped to endpoints for both ends but snapped off in the middle!
Yea, but could it dance a jig?
Hmmm that might require a spline, and a macro that moves the vertices back and forth 😛
I am trying to do this in AutoCAD Lt 2013, but I am having no success with it working. I, like the original post, am trying to get my dimensions to all be on a dimension layer and all my viewports (mview) on an mview layer.
Can you provide further instructions? I am editing the "Macro" line in the dim command from:
^C^C_dim
to
^C^C_dim-la;_make;Dims;;
The command you need to use first is -LAYER (there is a dash in the name), follwoed by the MAKE option (it creates the layer and makes it active, if the layer already exists it will simply make it active). Then you follow it with your desired 'other' command.
So, look at the top of this thread for the correct code (not yours): here is is spelled out for easier reading (replace DIM with the layer name you wish to use and replace DIMCOMMAND with the command you want to use right after it)
^C^C_-LAYER;_make;_DIM;;_DIMCOMMAND
Yes you have to know the name of the command you want to use right after setting the layer, HELP can walk you through it.
Note that using macros that layer remains set and active until you change it.
