AutoCAD LT General Discussion
*Hamm, Bob
Message 1 of 9 (8,225 Views)
Degrees, minutes, seconds
8225 Views, 8 Replies
12-16-1999 06:10 AM
Can anyone tell me how to set line direction by N,E,S,W by degrees, minutes
and seconds.
i.e.. drawing a plot plan laid out by a surveyor.
Must I convert to degrees for polar coordinates or is there a way to
directly insert these angles?
*Support, Autodesk
Message 2 of 9 (8,221 Views)
Re: Degrees, minutes, seconds
12-16-1999 09:48 AM in reply to: *Hamm, Bob
Bob,
You should be able to use these by selecting Format>Units and changing the
Angle Type to Surveyor Units or Deg/Min/Sec.
Keith Sibbert
PSG Product Support, Americas
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
> and seconds.
*Texidor, José C.
Message 3 of 9 (8,221 Views)
Re:
12-16-1999 10:53 AM in reply to: *Hamm, Bob
Use command DDUNITS and change to Surveyor Units as indicated by Keith.
To draw line, select a starting point and use something like this:
@12
@12 = distance
I hope my memory is still working ok...
Joe
Keith Sibbert (Autodesk Support) wrote in
message news:385925E1.3D545076@autodesk.com...
> Bob,
> Keith Sibbert
minutes
> > and seconds.
*Rudolph, Dietmar
Message 4 of 9 (8,221 Views)
12-17-1999 08:53 AM in reply to: *Hamm, Bob
>and seconds.
While you can have LT display angles and direction using degrees,
minutes, and seconds (via Format->Units), you have to enter angles and
directions using decimal degrees.
Dietmar Rudolph
President, CR/LF GmbH, http://www.crlf.de
Vice-President Europe, CADLock, Inc. http://www.cadlock.com
Webmaster, AutoCAD Developers Group Europe, http://www.adge.org
Member of the Autodesk Discussion Forum Moderator Program
Author, "Mastering AutoCAD 2000 Objects", http://www.crlf.de/Verlag/PublishingServices.html
*Texidor, José C.
Message 5 of 9 (8,221 Views)
Re:
12-17-1999 10:18 AM in reply to: *Hamm, Bob
To draw line, select a starting point and use something like this ie:
line from 0,0 to @12
@12 = distance
Joe
Dietmar Rudolph wrote in message
news:tWBaOBP6E16YTVPcmM3=8DRfbofP@4ax.com...
minutes
> >and seconds.
> Dietmar Rudolph
New Member
Tcastricone
Message 6 of 9 (5,139 Views)
04-15-2013 02:32 PM in reply to: *Hamm, Bob
from the autocad help button on the program. I am not sure why this wouldn't be the first thing that came up on the autodesk "help" on their website, but this is how you do it and it works.
You can specify the measurement conventions for angles so that positive values of angles are measured either clockwise or counterclockwise, and angle 0 can be set to any position. You can enter angles using grads, radians, or surveyor's units or using degrees, minutes, and seconds.
If you use surveyor's angles when specifying polar coordinates, indicate whether the surveyor's angles are in the north, south, east, or west direction. For example, to enter a coordinate relative to the current coordinate for a property line that is 72 feet, 8 inches long with a bearing of 45 degrees north, 20 minutes, 6 seconds east, enter
@72'8"<n45d20'6"e
Valued Mentor
sthompson1021
Message 7 of 9 (5,133 Views)
04-15-2013 04:36 PM in reply to: Tcastricone
Hi, while most people on this forum would agree with your assement of autocad help, the OP may be retired by now:smileywink:
*Expert Elite*
Charles_Shade
Message 8 of 9 (5,119 Views)
04-16-2013 05:00 AM in reply to: sthompson1021
Funny thing is back then there may not have even been online Help and it has only been the last four years that a simple query in Help would not yield
results.
Only a perfect query now of the exact phrase will work - maybe
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
*Expert Elite*
Bob_Zurunkle
Message 9 of 9 (5,103 Views)
04-16-2013 08:38 AM in reply to: Charles_Shade
Wasn't Kudo that mutant dog that did Kung Fu?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Post to the Community
New Post
Need installation help?
