AutoCAD LT General Discussion
Valued Contributor
Chisel
Message 1 of 8 (226 Views)
Customer Service & Support
226 Views, 7 Replies
04-23-2013 03:58 PM
Using the new webpage I am unable to post a report because the Release & Account boxes won't let me select anything.
Please Fix
philip.s
Message 2 of 8 (222 Views)
Re: Customer Service & Support
04-23-2013 04:35 PM in reply to: Chisel
My apologies for the inconvenience Peter.
Are you able to reproduce this issue / inability to submit a support request on multiple web browsers? If so, can you please send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your password or permission to reset so that I can troubleshoot accordingly.
Philip Schmelzer
Valued Contributor
Chisel
Message 3 of 8 (219 Views)
04-23-2013 04:40 PM in reply to: philip.s
Hi Philip,
Thanks for the quick reply. When I clk'd on the Philip.s link I get an error
message.
I use IE.10 and am up to date with all patches.
Regards
Peter Yorke GIPENZ
ENGINEERING WORKS LTD
engworks@xtra.co.nz
Cel. 0274 759987
Ph. 06 8788115
philip.s
Message 4 of 8 (190 Views)
04-24-2013 01:29 PM in reply to: Chisel
You're welcome Peter!
As mentioned in my previous PM, I reset your password today and since doing so was able to successfully walk through the process of creating a support request (without submitting) using your credentials on Chrome and Firefox. I believe that this issue should be isolated to IE 10 as it's not currently supported in the Subscription Center (more info can be found here).
Philip Schmelzer
Valued Contributor
Chisel
Message 5 of 8 (159 Views)
04-25-2013 01:18 PM in reply to: philip.s
Hi Ed, I have had a suggestion from Bill Glennie who suggested thatI clear the IE10 cache. This seems so far to have fixed the issue.
Thanks for your time.
Valued Contributor
Chisel
Message 6 of 8 (151 Views)
04-25-2013 01:39 PM in reply to: Chisel
Hi Ed,
No my mistake, I still cannot log in a fault.
As I do not wish to have to change my IE for another bit of software I will wait until it is supported.
The issue that I wanted to report is that my toolbars reset to the 1st monitor instead of staying on the 2nd.
I have saved the workspace but the software is not remembering to start up on this workspace. This fault is random, some days it gets it right and others wrong.
Is this some thing that you can help with?
DarrenP
Message 7 of 8 (149 Views)
04-25-2013 01:42 PM in reply to: Chisel
the same thing happened when IE 9 first came out it was incompatible with a lot of websites
pendean
Message 8 of 8 (129 Views)
04-26-2013 05:31 AM in reply to: Chisel
I have to agree with the above, newer IE versions always go through this: that's why most of us seasoned PC users never jump on a newer version of IE until it's been established (or avoid IE altogether).
Good luck, only time and compatibility upgrades by the various software and websites will fix it. Anything else is just temporary.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
