I am attempting to create a custom linetype with text in it, but the format used to create the line. Which is as follows: A,.5,-.25,["GAS",STANDARD,S=.1,U=0.0,X=-0.1,Y=-.05],-.25 is not producing the result I need. Asimple linetype is no problem but when I attempt to add text, it wont load into the drawing. I need to create a "gas line" because no matter what I do I can't read the text that is in the default gas line. I have tried any number of things to make the text larger, to no avail. Can anyone help?
Solved by Charles_Shade. Go to Solution.
Solved by sjw0465. Go to Solution.
Open up the .lin file in notepad.
Find the linetype GAS
Copy it to the bottom of the document
Change the name and text to OFC
Save the .lin file
Howard Walker
I am attempting to create a custom linetype with text in it, but the format used to create the line. Which is as follows A,.5,-.2,["4.16kv OHL",STANDARD,S=.1,R0.0,X=-0.1,Y=-.05],-.70. is not producing the result I need. Can anyone help?
See your other duplicate post https://forums.autodesk.com/t5/autocad-lt-forum/create-linetype/td-p/12204141/jump-to/first-unread-m...
Also, have you tried the tip right above yours yet?
