AutoCAD LT Forum
Cursor moving in a grid pattern
46 REPLIES 46
Message 1 of 47
white_n_slow
256859 Views, 46 Replies
Can someone please help me with this problem?
As I move my cursor around my drawing, rather than moving smoothly, it jumps in 1/2" increments (architectural). This means I am unable to place it over certain objects that aren't located on one of those spots on the 1/2" grid. If I zoom in pretty close on an object and move my cursor, it jumps right out of my screen.
Help please!
46 REPLIES 46
Message 2 of 47
in reply to: white_n_slow
You probably have the SNAP function on which makes the cursor move
incremental jumps at user-defined spacing. You can hit the F9 button to
turn it off and on, type the command SNAP at the command line or use the
SNAP button under the graphics area in the lower left corner.
George Drayton CD-CAD Ltd Christchurch New Zealand
Message 3 of 47
matthew_atlantabraves
I had the same issue and your solution worked. F9 had apparently been struck without my knowledge
Message 4 of 47
lmorris
I have same problem but my snap is not on!
What to do can you change the increments?
Message 5 of 47
pendean
in reply to: lmorris
Does this happen in all files, or just this one?
Message 6 of 47
lmorris
in reply to: pendean
Just checked In all. Im trying to make a line across an electrical drawing from the center of number. with out snap on,
and It just goes a little above or below center. I need it in center to match up the terminals.
Message 7 of 47
pendean
Is this a sudden new problem?
What LT version are you using?
Is this a new PC? what is the OS?
SNAP only works inside a command when it's on, are you aware of that? You still seem to be describing SNAP being on.
Otherwise you need to start GRAPHICSCONFIG command and turn off everything on that pop-up to see if that helps too.
Message 8 of 47
larry.cravey
I just had our IT department rebuild my laptop because of a OS problem when upgrading to Win 10.  When they reinstalled Autocad LT 2010, my cursor does not move smoothly when in a command.  It jumps similar to SNAP being on, but SNAP is OFF.  I have tried multiple solutions from the forums but nothing seems to help.  Any suggestions?   When not in a command, the cursor moves smoothly.
Message 9 of 47
pendean
in reply to: larry.cravey
LT2010 is not supported in WIn10 http://autode.sk/1IY4C2X (that means if we cannot solve this problem with you, no one out there ever will, not Autodesk, not Microsoft, not anyone).
Try these tips https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Cursor...
Message 10 of 47
Yup, Snap to grid. F9 fixed it for me too, thanks.
Message 11 of 47
Emmsleys
in reply to: lukestones
@lukestones
Thanks for sharing what helped!
Sarah Emmsley
Technical Support Specialist
Message 12 of 47
rkmcswain
larry.cravey wrote:
....It jumps similar to SNAP being on, but SNAP is OFF.  I have tried multiple solutions from the forums but nothing seems to help.  Any suggestions?   When not in a command, the cursor moves smoothly.
Your last sentence makes it sound like SNAPGRIDLEGACY = 0
R.K. McSwain     | CADpanacea | on twitter
Message 13 of 47
I was having this same problem and all the answers given were not working. However, I was able to figure out a solution: go to object snap settings, in the snap and grid tab revise the Snap Spacing to be 1/32" or your desired spacing. I do not know what makes this change on its own but mine somehow changed itself to be 1/2" spacing. I hope this helps!
Message 14 of 47
lmorris
in reply to: jessiesappington
Thank you, funny you sent message now. I just started doing it again.
Message 15 of 47
neshghi
Thankssssss. I had this problem and I tried many things but what you said fixed it.
Message 16 of 47
hsarchitype1
8 years later than your post but mine got set to 1".  Thank you.  Harry
Message 17 of 47
Cursor moving in the grid pattern can be solved by turning off the snap. It can be done by using command SNAP and turn off snap.
Message 18 of 47
As usual, AutoCAD proves itself to be the WORST SOFTWARE.
WHY ON EARTH WOULD JUMP AROUD THE SCREEN EVEN BE AN OPTION?!
None of these explanations or suggestions make any sense.
Why won't this software company die so Adobe can pick it up and make it better?
Message 19 of 47
Jump around the screen? As in your turned on SNAP (F9 toggles it on/off)?
Or are you experiencing another issue altogether?
Message 20 of 47
It is called SNAP and GRID. It has been in AutoCAD for probably 30 years. It is taught in AutoCAD classes on day 1. AutoCAD is not the iPhone of CAD software, and with the multitude of variables and options, comes a learning curve.
”Boost
