Hi all,
when i insert the title block template in model space (paper space too) , the cursor not move properly, i turn off and turn on of F8, F9 also its not move properly. lagging. what can i do?
kumar r
Welcome to the Autodesk Forums!
What is your AutoCAD version and computer specs. Also the video card.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
hi
my autocad version is LT 2011, platform windows vista (6gb ram). and graphic card is NIVIDIA Geoforce 9400GT
Try Turning Hardware Acceleration Off (or On if it is Off).
Do you have Palettes open? Especially Layer control.
Your template block probably contain to much information and entities for your computer to render it when you move it around.
You should upgrade your rig, get off Vista and upgrade to something better then the good'ol 9400GT
