AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Crosshair icon
6 REPLIES 6
Crass
586 Views, 6 Replies
Crosshair icon
What is this icon below-right of the crosshair?
I have never seen it before. I cannot even tell what it is supposed to be.
AutoCAD 2018/2021
AutoCAD Civil 3D 2021
Tags (2)
6 REPLIES 6
pendean
in reply to: Crass
Which of the rows of buttons, lower-left of the AutoCAD program window do you have pushed in?
Crass
in reply to: pendean
This is what my "lower left" button pallete looks like:
I was messing with Data Link some today. Could it have anything to do with that? I have continued to work and executed many different commands, but the icon remains.
AutoCAD 2018/2021
Crass
in reply to: Crass
A better look on a gray backround:
AutoCAD 2018/2021
braudpat
in reply to: Crass
Hello from France
It could be the HyperLink Icon ??
Have you create Hyperlink on some entities ?
If you select the object near the icon, then Right Button, have you some HyperLink options (at the end) in your context Menu ?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Charles_Shade
in reply to: Crass
Try the DATALINKNOTIFY System Variable. Set it to 0. Does the Icon go away?
Though Help does not say that Icon should be there I wonder if Dynamic Input has something to do with it if the Variable is the reason why it is showing.
edwin.prakoso
in reply to: Crass
It's a hyperlink. Your object is linked to a website page or other object. < br/>To see where it's linked to, hold CTRL and click the object. It will open a browser or a software to open the file
If you don't want to see it, type HYPERLINKOPTIONS then enter. Choose no then enter again.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
”Boost
