What is this icon below-right of the crosshair?
I have never seen it before. I cannot even tell what it is supposed to be.
Solved by edwin.prakoso. Go to Solution.
This is what my "lower left" button pallete looks like:
I was messing with Data Link some today. Could it have anything to do with that? I have continued to work and executed many different commands, but the icon remains.
Hello from France
It could be the HyperLink Icon ??
Have you create Hyperlink on some entities ?
If you select the object near the icon, then Right Button, have you some HyperLink options (at the end) in your context Menu ?
Bye, Pat
Patrice BRAUD
Try the DATALINKNOTIFY System Variable. Set it to 0. Does the Icon go away?
Though Help does not say that Icon should be there I wonder if Dynamic Input has something to do with it if the Variable is the reason why it is showing.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
It's a hyperlink. Your object is linked to a website page or other object. < br/>To see where it's linked to, hold CTRL and click the object. It will open a browser or a software to open the file
If you don't want to see it, type HYPERLINKOPTIONS then enter. Choose no then enter again.
