I've been racking my brain WHERE to find to set the size of my cross hair in LT 2010.
I've checked the Options and I can only see the setting for my grips, aperature cross hair size, and my object snap size. etc etc.
Am I just not seeing this? Can someone let me know where it is?
Thank you!
In LT2009 it's
TOOLS
OPTIONS
DISPLAY
and at the right hand side near the middle of the box is CROSS HAIR SIZE
Howard Walker
Cross Hair, Pick Box, Grip Size, etc... is still the same under Tools; Options; as Howard has written.
Nothing new in that regard for newer versions.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
In case others are reading this poasting... It has not changed since AutoCAD 2000/LT2000, location as noted above: I don't recall where R14/LT97/LT98 or earlier had it.
It's always been CURSORSIZE system variable it that helps too.
I just find your5 queries, and the solution was go with the tool bar and click on tools AND OPTIONS And find in display tab, the bottom option gives you the option.. hope you got waht yopu were finding for
