AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Create block array based on prompt
1 REPLY 1
DBalcar
223 Views, 1 Reply
I need to know if this is possible. My vision is when someone inserts "block A", a promt will come up and ask "how many of "block A" do you need?" Based on how many you need, it will insert the block along with the arrayed amount the user has typed in. Please let me know if this program is capable of this action or if you have a suggestion of another program capable of this.
1 REPLY 1
Charles_Shade
in reply to: DBalcar
Have you used or do you use AutoCAD LT?
The Array Command in the newer Versions (2012, 2013) works basically as you ask.
I'm not sure Array can be used form the Command Prompt as described from within LT.
You would need a program that offers more programming flexibility.
Full AutoCAD may provide this functionality thru programming.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
”Boost
