Solved by Charles_Shade. Go to Solution.
Have you used or do you use AutoCAD LT?
The Array Command in the newer Versions (2012, 2013) works basically as you ask.
I'm not sure Array can be used form the Command Prompt as described from within LT.
You would need a program that offers more programming flexibility.
Full AutoCAD may provide this functionality thru programming.
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
