Help! I just received a dwg from a consultant and when i go into paperspace
the door dimension is reading 6'-4" when i put a dimension on it.......and it should be 6'
the LTscale is 36, PSLTscale is 1 and MSLTSCALE is 0.....i need to scale the plan so those doors read 6'
the Dist is reading 6'-4 just like the actual dimension
when i list it it reads
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]:
Command:
Command: '_.-LAYER
Current layer: "A-Flor-Finish"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: _UNLOCK
Enter name list of layer(s) to unlock or <select objects>: =0
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: M
MOVE
Select objects: Specify opposite corner: 95 found
Select objects:
Specify base point or [Displacement] <Displacement>:
Specify second point or <use first point as displacement>:
Command: *Cancel*
Command: *Cancel*
Command: SCALE
Select objects: Specify opposite corner: 951 found
Select objects:
Specify base point:
Specify scale factor or [Copy/Reference]: .99
Command: *Cancel*
Command: *Cancel*
Command: SCALE
Select objects:
Specify base point:
Specify scale factor or [Copy/Reference]: .96
Command: *Cancel*
Command: *Cancel*
Command: SCALE
Select objects:
Specify base point:
Specify scale factor or [Copy/Reference]: .99.25
Requires numeric distance, second point, or option keyword.
Command:
Command:
Command: _.undo Current settings: Auto = On, Control = All, Combine = Yes, Layer = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: 1 SCALE
Command: *Cancel*
Command: *Cancel*
Command: SCALE
Select objects:
Specify base point:
Command: *Cancel*
Command: *Cancel*
Command: SCALE
Select objects:
Specify base point:
Specify scale factor or [Copy/Reference]: 1.1
Command:
Command:
Command: SCALE
Select objects:
Specify base point:
Specify scale factor or [Copy/Reference]: .5
Command:
Command:
Command: *Cancel*
Command: *Cancel*
Command: SCALE
Select objects:
Specify base point:
Specify scale factor or [Copy/Reference]: 1.27
Command:
Command:
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: SCALE
Select objects:
Specify base point: *Cancel*
Command: *Cancel*
Command:
Command:
Command:
Command:
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: 1 INTELLIZOOM INTELLIPAN INTELLIZOOM INTELLIPAN INTELLIZOOM INTELLIZOOM INTELLIPAN INTELLIZOOM INTELLIZOOM INTELLIZOOM INTELLIZOOM INTELLIZOOM INTELLIZOOM
Command:
Command:
Command:
Command:
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: 1 INTELLIPAN INTELLIZOOM INTELLIPAN INTELLIZOOM INTELLIZOOM INTELLIZOOM INTELLIPAN INTELLIZOOM INTELLIPAN INTELLIZOOM INTELLIPAN INTELLIZOOM INTELLIZOOM
Command:
Command:
Command:
Command:
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: 1 INTELLIZOOM INTELLIZOOM
Command:
Command:
Command:
Command:
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: 1 MOVE
Command:
Command:
Command:
Command:
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: 1 '.-LAYER '.-LAYER '.-LAYER Regenerating model.
Command:
Command:
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: MSLTSCALE
Enter new value for MSLTSCALE <0>: 1
Command:
MSLTSCALE
Enter new value for MSLTSCALE <1>: *Cancel*
Command: *Cancel*
Command:
Command:
Command: _dimlinear
Specify first extension line origin or <select object>:
Specify second extension line origin:
Non-associative dimension created.
Specify dimension line location or
[Mtext/Text/Angle/Horizontal/Vertical/Rotated]: *Cancel*
Command: *Cancel*
Command:
Command:
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: 1 DIMLINEAR GROUP
Command:
Command:
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: 1 INTELLIZOOM INTELLIZOOM INTELLIZOOM
Command:
Command:
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: 1 MSLTSCALE
Command:
Command:
Command:
Command:
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: 1 INTELLIZOOM INTELLIPAN INTELLIZOOM INTELLIZOOM INTELLIPAN INTELLIZOOM
Command:
Command:
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: <Switching to: Layout1>
Regenerating layout.
Regenerating model.
Command: Specify opposite corner or [Fence/WPolygon/CPolygon]: *Cancel*
Command: _.MSPACE
Command:
Command:
Command: _dimlinear
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: _CANNOSCALE
Enter new value for CANNOSCALE <"1:1">: 1/8" = 1'-0"
Enter new value for CANNOSCALE <"1/8" = 1'-0"">: 1/32" = 1'-0"
Enter new value for CANNOSCALE <"1/32" = 1'-0"">: 1/4" = 1'-0"
Command: _.PSPACE
Command:
Command:
Command: _dimlinear
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: <Switching to: Model>
Regenerating model.
Command: *Cancel*
Command:
Automatic save to C:\Users\mtupper\appdata\local\temp\FP_1_1_8329.sv$ ...
Command:
Command: DIST
Specify first point:
Specify second point or [Multiple points]:
Distance = 6'-4", Angle in XY Plane = 0.000, Angle from XY Plane = 0.000
Delta X = 6'-4", Delta Y = 0'-0", Delta Z = 0'-0"
Command: DIST
Distance = 6'-4 1/32", Angle in XY Plane = 358.493, Angle from XY Plane = 0.000
Delta X = 6'-4", Delta Y = -0'-2", Delta Z = 0'-0"
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command:
Command:
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: LIST
Select objects: 1 found
Select objects:
DIMENSION Layer: "A-Flor-Finish"
Space: Model space
Handle = 6bd65
associative: yes
type: horizontal
1st extension defining point: X=564'-5 3/16" Y= 65'-9" Z= 0'-0"
2nd extension defining point: X=570'-9 3/16" Y= 65'-9" Z= 0'-0"
dimension line defining point: X=570'-9 3/16" Y=66'-1 15/16" Z= 0'-0"
default text position: X=567'-7 3/16" Y=66'-7 15/32" Z= 0'-0"
default text
dimension style: "ARCH_048"
dimension style overrides:
DIMARCSYM 1
DIMFXL 3/32"
DIMLTEX1 BYLAYER
DIMLTEX2 BYLAYER
DIMLTYPE BYLAYER
Annotative: No
there is no viewport for im in modelspace
OP what does that door measure in modelspace? and have you tried unlocking the viewport, changing the VP scale and then changing it back? (don't forget to relock the VP)
