I have a problem with Autocad Lt 2014, when I insert an image, in the moment that I select the path Autocad crash immediately. But I can open a file with more images in, without a problem. Can you help me please?
I have this problem from july....I use the command insert..my autocad is in italian...the images are located in a server that is on network...is crash in all dwg files, even I start new one. My autocad is fully patched and update but I don't made the updating to Autocad 2015 because I'm afraid that the situation worst. I have Windows 7 professional 64 bit.
Can be a problem with archicad 17?my colleague had the same programs on her computer, but she hasn't my problem.
thanks
My colleague can insert images without problem on my file, if I copy/paste a line or a patch inside the same file I haven't problem also from another file, my commandline is docked.
But when I open an existing file and I want to "save as" I have a problem, in the moment that I click to find the folder in the network Autocad crashing, but if is a new file this doesn't happen. Now I tried to open a new file and I can insert images without problem, and I can save...but when I open an existing file I have many problems..I must all the time copy all the drawing in a new file? I can't work in this way.
thanks
