AutoCAD LT Forum
Crashing Autocad LT2010 and 2011
8 REPLIES 8
Message 1 of 9
MichaelGibson5012
478 Views, 8 Replies
Has anyone had the problem when printing pdfs then when closing the drawing it crashes?
I have had this problem for LT2010 and LT2011?
Running windows 7 64Bit
Cheers
Michael
8 REPLIES 8
Message 2 of 9
in reply to: MichaelGibson5012
What PDF driver are you using?
Are both programs on the same PC? If yes, did you "migrate" when installing
2011?
Dean Saadallah
http://LTisACAD.blogspot.com
Message 3 of 9
Yes both installations were on the same computer, only have the LT2011 and I did migrate the settings.
Also having fatal errors on a few other computers with LT2011? all with the settings migrated!!
Is it better not to migrate the settings?
Cheers
Michael
Message 4 of 9
Yes, migration is the problem: you had a problem in 2010, and by migrating,
you took it along with you to 2011.
Backup all of your files, and all of your customizations for both programs.
Follow Autodesk's Uninstall AutoCAD instructions:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=10243968&linkID=9240617
Dean Saadallah
Message 5 of 9
Thanks will try that and will let you know how I get on 🙂
Cheers
Michael
Message 6 of 9
Don't do anything if you have a deadline coming up 🙂
Dean Saadallah
Message 7 of 9
Dean,
The link you put in your previous message does not work
Michael
Message 8 of 9
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
Dean Saadallah
Message 9 of 9
Thanks 🙂
Michael
”Boost
