Hi everyone, i`m going to try to be as clear about my issue as possible, but...it`s driving me insane
i`m working on a drawing on autocad LT 2014, it was an existing drawing that I came into.
After a day of working on this particular drawing, if I would select and move my dynamic block while snapping it in the right location, I couldn't manipulate it anymore (height, width, etc) as if the snaps were missing.
Then I noticed then that whenever I did a simple line that I purposely aligned with something already in the drawing that the ability to shorten or lenghten the line dissapeared also (see screenshot)
Then I tried drawing a rectangle over an existing rectangle and...you guessed it, no snaps or ability to modify whatsoever
So obviously it's not just limited to one thing , for example just blocks, but pretty much any command that uses snaps.
I tried going into a other drawing and everything was fine, no issues, so it`s really that file. I made my coworker open it on her computer and it did the same thing.
It tells me that the file is corrupt (i`m assuming)
what i`ve tried and that failed 😞 :
-changing the name of the file
-copying it into a other drawing
-setting the osmode to 0
-purge and the advanced purge
-audit
-recover
-recoverall
oddly enough each time I do audit it finds 48 mistakes and says it's corrected 48 mistakes, I can do it 10 times in a row and it will keep giving me the same numbers over and over again.
I will hapilly give a cookie to whoever can help, thank you!!
Solved by pendean. Go to Solution.
