AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Copying objects
5 REPLIES 5
hwalker
437 Views, 5 Replies
Copying objects
This has probably been asked before.
I'm copying 1 object, mutiple times. Yes I know how to multiple copy.
The problem is this.
The object I'm copying will have varying distances between each copy eg, 50, 100, 90, 150, 140, 100, 190 so on and so forth.
Is there a way in LT to copy relative to the last object placed?
Howard Walker
Left Handed and Proud
5 REPLIES 5
pendean
in reply to: hwalker
No, you will need to write a very long macro that starts and stops then repeats COPY command a few dozen times.
hwalker
in reply to: pendean
Thought it would be something like that. Ah well shall fall back on my old way
Create a polyine with those distances and copy the object to the polyline endpoints.
Howard Walker
pendean
Macro would not be that hard, just annoyingly long (edit the repeat length as needed) and you need to ESC to cancel it when you are done.
First stab at it (not fully tested): ^C^C_undo;_mark;_select;$M=$(if,$(getvar,cmdactive),\)_copy;_p;;\@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\+
_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\+
_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C_move;_p;;@;\_copy;_p;;@;@;^C^C^C
hwalker
That looks really long.
Now I know nothing about diesel, but would it be possible to do the following
Copy
Select the object
Ask for the distance and put it in a user variable
copy the selected object the desired distance
erase the user variable
Select the object ...
Howard Walker
pendean
That's what I was attempting to write above I believe. Try it.
”Boost
