This has probably been asked before.
I'm copying 1 object, mutiple times. Yes I know how to multiple copy.
The problem is this.
The object I'm copying will have varying distances between each copy eg, 50, 100, 90, 150, 140, 100, 190 so on and so forth.
Is there a way in LT to copy relative to the last object placed?
Howard Walker
Solved by pendean. Go to Solution.
Thought it would be something like that. Ah well shall fall back on my old way
Create a polyine with those distances and copy the object to the polyline endpoints.
Howard Walker
That looks really long.
Now I know nothing about diesel, but would it be possible to do the following
Copy
Select the object
Ask for the distance and put it in a user variable
copy the selected object the desired distance
erase the user variable
Select the object ...
Howard Walker
