Hi, and thanks for reading this. I've browsed the other posts about cut/copy and paste, but didn't seem to find a question/answer that was what I was looking for.
We have Acad LT 2012, 64 bit on Win7. I've found that the paste option in my right click menu is "grayed out". If I select an object and use the keyboard Ctrl-C, and then Ctrl-P, the object will paste. If I select an object, right click to open the menu, go to "clipboard" then "copy", I can't paste by using the same steps. Paste (as well as the other paste options) is grayed and I can't select it. The biggest issue is that I can't "paste to original coordinates". I can still use the Ctrl-P to paste.
(Yes I can w-block it, or just block it, but that takes more time.)
Any ideas as to why it is grayed out in my menus?
Cary
Solved by Charles_Shade. Go to Solution.
Solution:
At the AutoCAD command line:
Not so much the right click copy. But the right click paste and paste as block grayed out issue. Not interested in a work around like close and restart the program or restart the computer in its entirety or even using ctrl+v. I know what the work arounds are. I have been an autocad user for over 25 years. Currently using ACAD version 2023 & Advance Steel Version 2023. This issue, in many other forums, has been stated that it will be resolved in the next version of the software back in 2010. I assure you that it has not been resolved. Workarounds only disturb workflow, solutions will restore them.
@egrote wrote:I assure you that it has not been resolved. ...
Reporting issues and desires are best done where Autodesk claims to look for them:
https://www.autodesk.com/company/contact-us/product-feedback
and
at Autodesk Support:
https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options/we...
