AutoCAD LT Forum
Converting Excel Spread sheet with XY coordinates into a Drawing
8 REPLIES 8
Message 1 of 9
riley_bouffard
1971 Views, 8 Replies
I don't use Cad very often however i need to find a way to convert an Excel spreadsheet with xy coordinates into a drawing in AutoCad LT. Probably very simple, but again i am a beginner. Edited by: riley_bouffard on Dec 30, 2008 7:13 PM
8 REPLIES 8
Message 2 of 9
This is a spreadsheet from Brad I believe that I used to get me headed in the right direction. Search this discussion and you will find answers and help.
Charles Shade
Message 3 of 9
thanks for the help, if i know the equations for the lines i want to enter is it easier to enter those? If so how
Message 4 of 9
Equations? Are you generating answers within the spreadsheet?
I use the attached to set up stair geometry and just copy/paste the Point information for # of risers I want into a PLINE at the Command line. Cocantenation is the key: &
Charles Shade
Message 5 of 9
in reply to: riley_bouffard
AutoCAD can't deal with the equations directly.  You need to calculate
points and input them along with the commands to make a script.  Either
post or email a copy of your data and I will take a look at it.
Brad
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Equations?
I use the attached
Charles Shade
Message 6 of 9
Brad,
Thanks a lot, I got this job dropped in my lap because everybody who knows how to use cad decided to take the rest of the month off. I attached the data. I don't know how sensitive Cad is so i included all of the decimal points. The picture should be a simple curve. I can't thank you enough for the help.
Message 7 of 9
Run the PLINE command and Paste column E from Excel at the command line. Run PEDIT and Spline the object to get a curve.
regards,
cshade
Message 8 of 9
Thanks much easier than i thought
Message 9 of 9
That was much easier than I thought too!  I
did not have to do anything! Glad I could help.....  😉
Thanks cshade for taking care of this.
Brad
”Boost
