AutoCAD LT Forum
Convert .step, .SLDPRT, .ipt and .catpart to Cad
4 REPLIES 4
2003 Views, 4 Replies
Hi all,
I do appreciate in advance for your help. I have some files in formats mentioned in subject of this post which are free downloadable 3d models in GRABCAD websie. I need them to in auto cad 2013 or 2012 format (.dwg or dxf) or any other format like .iges so i can import them into auto cad. I've searched a bit on google to find a converter but I could not. So I am asking for a free converter or any body can save them as a cad file for me.
here is the links:
pipe
http://grabcad.com/library/hoover-pipe
http://grabcad.com/library/50-mm-twisted-tube-for-ventilation
http://grabcad.com/library/flexible-tube--2
cyclone
http://grabcad.com/library/sheetmetal-paper-trim-cyclone
http://grabcad.com/library/ciclone-cyclone
vacuum pump on cyclone
http://grabcad.com/library/vacuum-pump
http://grabcad.com/library/agni-motor-95r
motor
http://grabcad.com/library/motor-weg-324ts-esquerdo
http://grabcad.com/library/electric-motor-256t-frame
http://grabcad.com/library/gamak-100l-3kw-electric-motor
screw
http://grabcad.com/library/plastic-extrusion-screw
http://grabcad.com/library/extrusion-screw
http://grabcad.com/library/extruder-screw
http://grabcad.com/library/screw--21
tube as a barrel
http://grabcad.com/library/can-or-tube-for-reflex-suppressor
mold
http://grabcad.com/library/plastic-injection-mold--2
http://grabcad.com/library/unscrewing-mold
http://grabcad.com/library/plastic-mold-injection-1
http://grabcad.com/library/cover-mold
http://grabcad.com/library/mold-duas-placas
chair
http://grabcad.com/library/plastic-kiddies-chair
All the best.
4 REPLIES 4
Charles_Shade
I would suggest continuing your research to see what Autodesk program may open these files.
If there is a 30 day Trial of that software download it and Convert to your hearts content.
This too would be free for the thirty days.
pendean
See your other post, you got replies there and you are not using LT:
http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012-DWG/Convert-step-SLDPRT-ipt-and-catpart-to-CAD/...
in reply to: Charles_Shade
Hi charles, thanx for your advise, but i Got limitaion on doenload. so i can not download thi trial versions. because they are too big. but thanks.
in reply to: pendean
@pendian
will check. thanks.
”Boost
