AutoCAD LT Forum
convert 3d drawing to 2d
4 REPLIES 4
3120 Views, 4 Replies
I have a 3d drawing that I want to make into a 2d drawing. Does anyone know how to do this?
4 REPLIES 4
Put this in a button. It is from a previous post.
^C^C_UCS;;_move _all;;0,0,1e99;;_move
_all;;0,0,-1e99;;_chprop;_all;;_thickness;0;;^M;
Brad Yarger
wrote in message news:4880923@discussion.autodesk.com...
how to do this?
Hi Brad
Not sure what happens when I use this button !
I have a difficult intersection of two buildings to draw in LT.
I have drawn the plan and rotated the objects in plan so that one of the two buildings are now on an orthogonal plane.
I would like to draw the remainder in isometric.
Previously when in full AutoCAD i would change vpoint to 1,1,1
increase the thickness of objects and then plot to a dxb file.
New file, Dxbin, rescale the objects and I'm away.
How can I do this with autocad lt 2005 ?
DXBIN is not an LT command.
I just want the proportions which are correct in 3D to assit with 2d Isometric.
Many thanks
Jason
I am not sure I understand what you are doing, but the routine will
eliminate all Z data and I don't think that is what you want to do.
Brad
wrote in message news:4886783@discussion.autodesk.com...
Hi Brad
Isometric.
Many thanks
Jason
Ive been using the flatten lisp for cad lt that i have seen posted in many forums where it changes all the z values to 0 and it seems to work well when the view is set to top, bottom or either side. Is there any way to flatten a 3d model in cad lt when the view is set to an isometric view. I have searcched for ages and thought maybe if i changed the ucs but i still couldnt get it to work. Any help would be greatly appreciated.
”Boost
