I have a text style I like and it works nicely annotative. So long as I am in my drawing using my menu I am fine. When I go to a palatte and try to utilize some of the premade blocks it populates another font. How can I get my font to either be universal or change it at the root of the block?
Is the Textstyle name you are using STANDARD by chance?
Are these OOTB Autodesk Blocks?
Can you post one that does this to you in a drawing that has your Textstyle that you want?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
See the screenshot attached: your blocks are defined with the wrong font as defined in the STYLE command.
See screenshot, you can fix it there in each file or you need to edit each block at the source and change the STYLE being used. Look up STYLE command, this is where the pop-up in the screenshot comes from.
You can and must change all of these on your own: AutoCAD will not do it for you.
The 'good'ones are stock AutoCAD blocks: I have no idea where you go the others from but you can look up the source from wherever you grabbed the blocks in the first place.
So where did you get them from to put in your file?
