F2 to see the full text screen, is the info there?
If yes, the command line needs to be a minimum 3-lines tall: is it?
Also check your UNITS setting: the more precision you need the more lines
you need to set for command line.
Dean Saadallah
http://LTisACAD.blogspot.com
