Noticed a few days ago that my _Copy command (co) has changed from being standard set to "multiple" to being displacement.
I rather like it when it is standard set to multiple, now I've tried finding out why it has changed and I noticed under commands on "Copy" that the macro-string had been changed *I think*
$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_copy,^C^C_copy)
I havn't touched it, but as I recall it should not be standard look like that?
How do I get my _Copy command to be set Multiple again?
Thanks in advance
/Adam
Solved by AcadAdamLT. Go to Solution.
Ridicolous when you go back to basics and find the answer right away
During the command after selecting objects you can go into MOde and change it from Single to Multiple.
Also make sure your PICKADD variable is set to 1
Howard Walker
