1.Use the Monochrome plot style table in PLOT. Or create your own.
2. Not if it is Mtext, that needs to be set inside the text editor, a
feature of that style of text.
3. You will need to redefine the block, redefine all the attributes to be
bylayer if they are the same layer, sometimes they are not, then re-insert
the block and re-enter the attributes.
#1 would pretty much be the quick fix here.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
