AutoCAD 2012 LT is not registering Color Dependant Plot Styles. It previews the .dwg correctly before plotting but does not plot as it should. Can someone provide some insight?
I knew it was a problem with AutoCAD when i tried printing the exact same file with the exact same plot style in draft sight and it worked.
Apperantly this issue has been happening with AutoCAD LT for years, I think its a bug. Anyways someone provide a fix please.
PS: no problems plotting with named plot style or setting a line width
it doesnt plot as the preview, line weights as per plot style. Line weights overritten plot fine, it just doesnt plot the line weights set in the plot style, it shows in the preview correctly with all the line weights but once plotted it plots as if the plot style were "monochrome"
I'm plotting to a SIL Teriostar LP-1000L Driver V1.88
they are .ctb plot styles
Windows XP
The issue is consistent with color dependant plot styles
