Hi
is there any way that i able to choose 2 or more layer at the same time? I am trying to change some layers , with quick select or layermerge I have to go one by one, I wonder if there is another way to this?
Do you have the layer properties toolbar visible? If so there is an icon to the left of the layer name (outside the white area) which is called 'Layer Properties Manager' click on that and the layers dialog box will appear
Typing Layer on the command line will do the same thing
Now you can select multiple layers.
If the layers are next to each other click on the first layer, hold down shift and click on the last.
If the layers are not next to each other click on the first layer, hold down ctrl and click on the other layers you wish to change
You can now change the properties of these layers all at the same time
Howard Walker
good idea but,
you can change the properties this way and you cant make them all in one layer! i mean I want to choose 3 layer all together and change the layer name so instead of having 3 different layer I have one.
Right
There are least two ways to do what you want
One is the properties painter (Matchprop),
Choose an object on the layer you want the others to be on and click it. Now choose the other objects.
BUT there are flaws with that in that unless you set the properties correctly it can mess up text sizes and the such like
Another way is very simply select all the objects you want to change the layer for, and remember that layer toolbar I mentioned. At the RIGHT of the layer name you will see a downward facing black triangle. Click on that.
All you layers will now be listed. Click on the layer you want your objects to be on, and now they will all be on the same layer.
Howard Walker
Hi, the way I would do it is to use layer isolate. Just select one object from each layer and hit enter. Then select everything and open the properties box and change layer from varies to the layer you want. You can also choose to change colors, linetype, text style, whatever to bylayer or leave as is.
