I have a problem when I launch Autocad LT 2010. The progam start to run but the screen remains motionless and the menus do not appear. Another thing, i can't do anything on the product and I'm obliged to close Autocad with the task manager.
Thanks for your reply.
Solved by pendean. Go to Solution.
This is not a new pc and i use Autocad 2010LT since 2010 so no fresh install. This problem appears last thursday. Befiore That, I had a similar problem but it was solved by a suppresion of folders in C:\users\username\appdata\local\autocad and C:\users\username\appdata\roaming\autocad. But this time it doesn't work.
I think it's a godd asnwser to your question but if you nedd more details, ask me.
I try Windows System Restore and it's ok. But I haven't turn off automatic Windows Updates. Can you tell me which KB is the source of the problem and i will desactivate only this. I don't want to turn off windows update because of security.
Thanks again for the solution.
