For years we've had a linetype change toolbar that worked just fine. This years update may have changed something that the old macro is missing or doesn't need anymore because none of the commands work anymore. One of the macros reads:
^C^Cselect \chprop;previous;;ltype;dashed;ltscale;4;;
Does anyone see anything wrong with this? Or maybe see a different way of doing it?
KB
Solved by Johneng. Go to Solution.
What is your PICKADD system variable set at? Initial value is 2 which screws up the SELECT command portion of your macro. If PICKADD is set to 2 change to 0 or 1. See the following link for more information on the PICKADD variable.
