I created a associative and annotative hatch for a group of objects. It displays fine and the area measures fine. When I switch the annotative scale in the lower right for the whole drawing, portions of the hatch dissapear from the boundary objects - both visually and from the area in properties, When I switch back to original annotative scale, that area is still no longer there. In essense, parts of the hatch get deleted.
See the attached screenshots.
Solved by pendean. Go to Solution.
Tried a REGEN?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Yes. Many times. Regen and regenall.
The fact that the hatch insertion point shifts and the area # changes tells me this is more than a display issue that regen would fix.
Thank you Dean.
Here are the results of tinkering with these commands:
None of this has addressed the problem. It is just one problem as I see it: I actually lose geometry by chaning annotation scale. The area of the compound hatch changes. It is not a display issue.
I really think there is some sort of software bug here. I already wblocked out the problem hatch and boundary geometry and remade the hatch multiple times in this new simple drawing.
Is there a Z value other than Zero?
Not for the hatch. And the only other geometry is the regions used to create the hatch. So I don't think so. I will post the file
The problem occurs when I change the annotative scale to 1"=200' for example. Notice how the hatch disappears at the upper part of the drawing, even when you switch back to the current annotative scale.
The Hatch does not dissappear here: LT 2014
The Scale of the Hatch changes as I would expect for the three Annotative Scales you have assigned to the Hatch. 1:60. 1:100. 1:200
All other Annotative Scales when active do not affect the Hatch at all.
Ths is the same across all regions of your drawing.
See attached: I created a new single hatch across all 66 regions and it seems to have stopped the problem.
You're right Dean. That worked. Thanks for your help. I wonder why that happened? It is a little disconcerting as I could have missed that and continued working. I should have tried to remake the hatch again as you did. Did you select all objects at once when creating the hatch?
As an aside, I might switch away from using regions. I like that they give areas for compound shapes, but they are difficult to edit and lead to performance problems - even when I hover over a region in an xref, my system grinds to a halt.
Thanks again!
