I'm using 2004lt- I have current .dwg in modelspace and set up to plot in PS@ 3/23"-1'-0". I'd like to create a second set of PS tabs to plot portions at 1/4"-1'-0" on the same border when needed.
In its a single viewport in MS and PS the current scale is 1:1 but if i change it to 1/4"-1',etc the plot preview appears wrong, any helpwould be helpful
The simplest way to have done this would be to have Plot Scale at 1:1.
Meaning that the paper you see and your Title block are all real sizes.
When set up like this you can make the Viewports the scales you need for oyur views.
Questions:
Paper size?
Plot Scale?
Is the title block sized for this Plot scale?
Viewport scale?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
