When I highlight multiple tabs, right click a selected tab and pick "publish selected tabs", only the first of the selected tabs is printed (as pdfs). If I use the pull down menu and select publish, all the tabs are selected in the publish window and I can delselect them but my normal routine of highlighting tabs, right clicking and publishing is not working. Is this a bug or a feature?
Solved by cadman70454. Go to Solution.
I same your problem, but I using CAD 2016 LT. Please, Audesk support to help me and Cadman
