Cannot open multiple drawings in a single session as i could till today.
I found a similar thread but that was for 2000lt... I am using 2010.... and tried relevant advise...
I tried SDI etc..
HISTORY
I recently downloaded Autodesk Dwg Viewer to convert a later version dwg....
Experimenting with the new Dwg Viewer today, i opened a dwg. file from a folder on our server... right clicked... OPEN WITH and selected open with dwg viewer...
To my surprise ALL the dwg icons on our server changed... (not just the drawing I wanted to open with the viewer) and after that all dwgs started to open with Autdesk VIEWER when double clicked.
So I repeated the process to reverse what I had done... ie. Right click... OPEN WITH then browsed my way to the AutoCAD 2010.exe file and selected that.
Files now open AutCAD 2010 program... but never open into the current session. I end up separate sessions and for various reasons do not want that.
CURRENT SETTINGS
FILE DIA = 0
SDI = O
STARTUP = 0
How do I get drawings from the the server folders to open in the current session.
Thanks!
Solved by pendean. Go to Solution.
Thanks Dean
and for the super prompt response...
Followed your advice... It is still opening in separate sessions.
WHAT I DID
From .dwg file on server I right clicked/I set OPEN WITH to dwg launcher. That opened ok. Then saved and closed the drawing. Then closed the program.
Next... I restarted the program (LT2010) by opening a .dwg file on the server... save & close. Then close program.
Then I opened program again from my template.dwt file. Whilst that session was active I opened another .dwg from server folder... Result = separate session.
BTW: I did not touch the dwg VIEWER program at all.
Whatever method I use it still saves in separtae sessions except as follows.
OF NOTE
If I open my .dwt (or any .dwg for that matter) then while in that session... FILE/OPEN and browse from within the LT2010 program to open another file it will open in the same session ( ).
That is one positive but I still need to open files from server folders that open in the same session.
Another thing I just learned..
If I open a server .dwg file by: Browse/Select .dwg/Right Click/Open With/ Dwg Launcher... it will open into the same session...
Does that info help?
I cannot find DWG Launcher in my open with window.
Can someone help me find DWG Launcher in my system.
