I had a virus get on my computer and had to do a reformat. After re-installing AutoCAD LT I cannot open it unless I select "Run as adminstrator." Even after uninstall and reinstall it was doint the same thing. Since I couldn't find a solution at the time I set it to always open as administrator so I could work and look into the problem. I still have that issue, but now I cant properly open some dwg files. The fiel opens, but displays nothing. If I have someone else open the same file on their computer, the can see everything.
Does anyone know how to get it so I don't need to always select run as administrator? I never had to do this before and I'm already set as an admin on the computer.
Hello
Welcome to the Autodesk/AutoCAD Forums !
Well you don't give us the most important Infos ...
Q1) Which ACAD LT exactly ?
Q2) Which Service Pack installed on your LT ?
Q3) Which Windows exactly ?
Win XP Pro, Vista, Seven, Win 8.0, Win 8.1 ??
Q4) How much Ram in Gb on your PC ?
2/3/4/6/8/more ??
Patrice BRAUD
