AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Cannot Explode Objects?/ Some Objects I Didn't Group?
10 REPLIES 10
Message 1 of 11
asbuiltjmh1
10433 Views, 10 Replies
In model space, I have a number of objects that I didn't group together. This set of objects includes perimeter walls (grouped), a window assembly (grouped seperately).
This is a first for me. I want to explode all objects in dwg. every line, even those that I didn't group are selected when I
select a single line?
I've followed the procedures in help, knowledge base, to no avail.
Any suggestions?
10 REPLIES 10
Message 2 of 11
hwalker
in reply to: asbuiltjmh1
Type in GROUP at the command line
A dialog box should appear.
Untick and then tick again INCLUDE UNNAMED GROUPS
The box should now be populated. Select all the groups and then click on UNGROUP (second icon on the right hand side of the dialog box)
And you should have no more groups
Howard Walker
Left Handed and Proud
Message 3 of 11
asbuiltjmh1
in reply to: hwalker
I'm using Acad LT 2012. Typed "Group" in C-line, I get no dialog.
On C-line I get:   Select objects or [Name/ Description] "
Not sure where to  go from here?
Why don't i get a dialog box?  something set wrong?
Message 4 of 11
Charles_Shade
Hmm... No dialog here either
I'd like to hear more as well
Message 5 of 11
pendean
in reply to: Charles_Shade
That's what happens when a full AutoCAD user tries to help LT users 🙂
Everyone with LT, look up QKUNGROUP command.
Message 6 of 11
Charles_Shade
in reply to: pendean
I bow to the Sage of the Forum.
Use ALL for the Selection and works a treat (for you Howard)
Follow up - Took three clicks in Exchange and an expansion or two to come across that Command if you did not know it exsisted (which apparenlty we did not).
http://exchange.autodesk.com/autocadlt/enu/online-help/search#WS1a9193826455f5ffa23ce210c4a30acaf-6a...
Message 7 of 11
hwalker
Works fine in LT 2009 which is what I use Smiley Tongue
EDIT: it calls up a command called PKFSTGROUP
Howard Walker
Message 8 of 11
pendean
LT has always had PKFSTGROUP and QKUNGROUP, but if you only ever tapped a toolbar button or menu entry they were masked as GROUP and UNGROUP: many an irate LT user who switches to full AutoCAD realizes that LT can be unique and exclusive too.
The full AutoCAD method is, to say the least, clunky and not user friendly: see the post above on how it's done there.
Message 9 of 11
asbuiltjmh1
OH Great and Wondrous Zen Masters, it worked !
My 31 yr old son says not to use !!!!!! exclamation points in e-mails. I'm old school. Emotion is good!
Thanks for the assist. Much appreciated pendean ****Sage! & HWALKERSmiley Very Happy
Edited by
Discussion_Admin
Message 10 of 11
nicholasloke
QKUNGROUP   no longer ungroups  groups nested within groups in LT2013.  It worked for me in 2012 but not in 2013.   Any ideas?
Message 11 of 11
pendean
in reply to: nicholasloke
A wishlist item that got answered perhaps: seems like a great idea to me 🙂
”Boost
