I cannot edit any block attributes in my drawing. When attempting to do so, the command line states: "The object is on a locked layer". All of the layers in my drawing are unlocked, on and not frozen.
Any ideas?
Solved by hwalker. Go to Solution.
Go into the block editor and check the layers there as well. I have noticed that the layer states inside blocks can be different to layer states outside blocks.
Howard Walker
