AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Can't view layer properties manager
10 REPLIES 10
Message 1 of 11
Eldritch
4553 Views, 10 Replies
LT 2014 and 2015.  when I call up the layer manager I only see the filter, status and name columns and the whole thing is docked next to my drawing area.  No scroll bar to view columns to the right of name column so I cannot view or change any of the layer properties.  how do I stop the Layer Manager Docking?
10 REPLIES 10
Message 2 of 11
rkmcswain
in reply to: Eldritch
As a temporary workaround, set LAYERDLGMODE to 0 and try the layer command again.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 11
Eldritch
in reply to: rkmcswain
OK.  This didn't change the accessibility to the layermanager.  Wen I call t Layer Manager I have a docked fixed view left of screen of the first two columns only.  See attached screenshot.
Message 4 of 11
rkmcswain
Well, maybe LT does not support this variable. When it's set to 0 in AutoCAD, you get the old modal layer manager
(1) What is preventing you from UNdocking the Layer Palette?
(2) Does the command "CLASSICLAYER" do anything?
Message 5 of 11
pendean
undock your layer palette, does the problem go away?
Message 6 of 11
Eldritch
Classiclayer command gives what I want but does not affect docked pallette.
I don't know how to undock Layer Manager pallette
Message 7 of 11
pendean
Click and hold the title, drag it to your screen?
LAYER and CLASSICLAYER are two separate commands: one does not affect the other.
Message 8 of 11
Eldritch
Close post guys. Thank you for your time. I was getting a command barred red symbol when I tried to undock it. I have now managed to find and uncheck [allow docking] and it is all fine. signing off.
Message 9 of 11
LetitiaS
in reply to: pendean
I just loaded AutoCAD LT 2015 onto my computer yesterday.  My layer properties manager is locked on the left side of my screen (not docked, just stuck).  I can only see the Filters, Status, & Name columns.  It will not let me uncheck the "allow docking."  It won't let me move it to the middle of my screen by dragging & dropping it.  It won't let me stretch it out so I can view the other columns like linetype.  How can I fix this?  I can't change my linetypes because I can't see that column.
Message 10 of 11
pendean
in reply to: LetitiaS
See your other post.
Message 11 of 11
pleonian
Command:
LOCKUI
value "1"
FIX
From Argentina
”Boost
