I've tried setting "Options" > "Plot and Publish" > "Use as default output device" to both "Default Windows System Printer" as well as "HP Officejet blah blah blah".
I've double checked that my printer is in fact set as the default windows system printer.
Nonetheless, every single time I print, "Printer/plotter" is set to "None" and I have to select my printer manually.
This is perhaps my biggest single Autocad pet peeve.
Solved by pendean. Go to Solution.
Solved by Charles_Shade. Go to Solution.
Have you tried PAGESETUP yet?
Or right clicked the Modelspace or Layout (when active) tab and set the Printer yet?
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
First time AutoCAD user? Or first time out on your own? Or it's been a while since you used AutoCAD, or a recent upgrade from a very old version that had everything set for you?
FACT: AutoCAD never has and does not allow you to set a default printer like other programs for every file you open.
Never. Plot settings are stored in each file, in each tab, separately from the system. Whether you have that printer/plotter that is defined in that file's tab or not. The file creator, or "author", has sole control. Basic AutoCAD 101.
So how does the OPTIONS setting work? Tap the HELP button on that pop-up and find out. It's very limited.
Post back and explain whether the file you are trying to plot from came from someone else, or is one you started, or one of your older templates, and if you recently changed PCs or LT versions or printers/plotters so that we can understand where you are, in order to help you get to where you need to be.
>>FACT: AutoCAD never has and does not allow you to set a default printer like other programs for every file you open. Never. Plot settings are stored in each file, in each tab, separately from the system. Whether you have that printer/plotter that is defined in that file's tab or not. The file creator, or "author", has sole control. Basic AutoCAD 101.
Thanks for this, I understand now. Though "First time user?" "AutoCAD 101" felt a bit more condescending than necessary. AutoCAD has so many zillions of settings - and inexplicably hides so many of them, for example by not linking to PAGESETUP from the PRINT menu or even the OPTIONS > PLOT AND PUBLISH menu - that one hardly needs to be a n00b to be unaware of some.
I think this is a bizarre way of setting things up. It's just begging for conflicts; begging someone to set PAGESETUP to their specific printer instead of "default windows system printer" and then send it to someone who has a different printer. System-wide is 100% the right way to do default printer settings.
Oh well, I got around the problem by changing the PAGESETUP option on my default template.
Very interesting. Sounds like PAGESETUP (or equivalent) option from pre-2000 formats isn't read correctly by modern versions and this option corrects that...
I think they need to rename it, though. It sounds like it does what PAGESETUP actually does.
That's what Page Setup is for at the top of the dialog.
And it is easier to respond if we have a better understanding of your comfort with the program.
it's hard for a reader not to add emotion to something they read: no insult intended on my part, just making it clear this is a core 20+ year way AutoCAD does things.
Autodesk does a pretty good job of adding HELP buttons on all pop-ups that go directly to the required page to explain features a user that select: and unless you turned it off, there are also pop-ups that appear explaining items if you hover for more than 0.5-second over them all around the interface. I'm honestly not sure what more they can do to get a user to look things up. If you've got any, do share.
I noticed in your reply you missed a crucial point: Autodesk through AutoCAD gives total control to the DWG file creator/originator, not the recipient, when it comes to output. That's the correct method IMHO. The trick becomes is how to get the file originator to create templates and pagesetups (separate from PAGESETUP command) to manage his/her actions and files: I think this is were training (classes, or good books, or online tutorials) come into play.
Training: vital in today's business climate.
PAGESETUP did solve the problem on single file base.
Does that mean I have to do PAGESETUP for all the drawing to re-setup? I have thousands of drawings saved with old printer which is obsolete now.
That is true from AutoCAD 2000 forward, but pre-AutoCAD 2000, whatever printer you last used was the "default" of sorts. There were no page setups, and the printer name was not saved in the DWG file.
Whatever was your last used printer, in effect, became the "default" for the next file you open, regardless of how you last printed that particular file.
This would be a really GREAT feature in AutoCAD LT 2020:
I am so very tired of having to select the printer (from a very long list with many similarly-sounding printers) each time I want to make a quick print.
You are doing it wrong then. If you are using DWG files that you control, set it once in your template drawing(s) and be done with it. If you only work on drawings authored by others (you don't control the template), then create a script to automate the page setup process. One click and you are done.
