I cannot select a view to edit. I can select other objects. I can select views in other drawing files. It used to work just fine. I am running AutoCAD LT 2013
Solved by mmacdonald. Go to Solution.
Found the solution. I had inadvertantly turned off the "0" layer. I turned it back on and it works just fine.
