Hello everyone,
I can't able to purge the linetypes in the attached drawing. It is an empty drawing(I deleted everything to purge the linetypes), only "0" layer, no x-refs, no layout, but still I cab't able to purge them. Could anyone please help me where the problem is?
I'm using ACAD LT-2014.
Thanks in advance,
Jnanesh
Solved by rkmcswain. Go to Solution.
Those look like the result of the infamous DGN linetype bloat issue.
See the link below, which includes a link for a fix for 2013 and 2014
The fix is built into 2015.
There is no fix for 2013 or 2014 LT, but there is a workaround listed.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD...
