AutoCAD LT General Discussion
New Member
a_evie
Message 1 of 3 (270 Views)
can't print pdf
270 Views, 2 Replies
01-18-2004 09:09 PM
(1) Am using Light 2002. Does it support printing of PDF files?
(2) Am using an OCE TDS 400. Tried printing from Acrobat Reader 6.0 using the said plotter. However, the drawing never comes out completely. Its always 65-70% of the drawing. Would you be able to help? The drawing is A0 size but the images that comes out is as mentioned 65*70% only.
TQ!
*Dean Saadallah
Message 2 of 3 (270 Views)
Re: can't print pdf
01-19-2004 05:41 AM in reply to: a_evie
1. PDF printing depends solely on the printer driver you use to create the PDF, and has nothing to do with LT or any other program you use to print to PDF (read, they don't need to 'support's printing PDF). So what are you using as the printer driver to create a PDF? 2. Have you considered asking ADOBE support? They has discussion groups like this that deal with nothing else. Also OCE's website for similar discussion areas. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
*Dean Griffin
Message 3 of 3 (270 Views)
Re: can't print pdf
01-20-2004 07:19 PM in reply to: a_evie
I'm not familiar with your printer but we had the same problem printing pdf's to our A3 laserjet. The solution, for us, is to reduce the printer resolution from 1200 dpi to 600 dpi when printing pdf's (or images for that matter). I believe additional printer memory would solve the problem too. "a_evie" wrote in message news:30013593.1074488988296.JavaMail.javamailuser@localhost... > Hi, > > (1) Am using Light 2002. Does it support printing of PDF files? > > (2) Am using an OCE TDS 400. Tried printing from Acrobat Reader 6.0 using the said plotter. However, the drawing never comes out completely. Its always 65-70% of the drawing. Would you be able to help? The drawing is A0 size but the images that comes out is as mentioned 65*70% only. > > TQ!
Announcements
Need installation help?
