we have bought aclt 2013 and we have got a problem with some files created wtih older versions of aclt.
When we try to open the file (plan), the file name appears but the progress bar don' t move then the file close.
HP Z620 12Go W7x64
Have you ever seen it ?
Can you help me please?
thank you for your reply,
my autocad lt 2013 is up to date. Y tried to purge, to recover (with xref, without xref), I tried to change policies but the way is the same, the plan try to open but can't be opened and my autocad don't crash y just have the soft but no plan and no error message.
Thank you for replying.
I have managed to get around the problem by opening plans with DWG Editor 2008 Dassault System after tools / save the block on the disk .dwg format and select [*] Register for all.
Then open with Autocad lt 2013 and it works.
I still do not understand why Autocad 2013 lt n 'not directly open these plans.
I ve download Autocad lt 2014 trial and it opens the plans without problems ...
Bug fix with aclt 2013 ?
Thanks for your help.
