AutoCAD LT General Discussion
Distinguished Contributor
madcowscarnival
Message 1 of 11 (2,190 Views)
Can't install True View 2013
2190 Views, 10 Replies
07-27-2012 06:56 AM
Can anyone help in very short order.  The Architect posted a drawing that I must print in 2012 format (she forgot to save to 2004).  I have tried 6 machines in our office this morning, attempting to get True View 2013 to run.  The exact same error problem that plagued my attempts to use True View 2012 are occurring.  True View says .NET 4.0 isn't installed.  The problem is, that it is installed and running correctly.  In two of the machines I went through the repair process of .NET 4.0 to see if there was a problem.  There wasn't, no change; True View still errored out before installing.  Is this a problem with buggy software?  Are there any other options open to me?  I don't know why they stopped updating True Convert.  It was far superior and not full of programming/install bugs.
madcowscarnival
Message 2 of 11 (2,188 Views)
Re: Can't install True View 2013
07-27-2012 07:06 AM in reply to: madcowscarnival
As an update.  I also downloaded the 64-bit version to try on the Windows 7 computers (all with .NET 4.0 already installed).  Same error: .NET 4.0 not installed on the computer.
Charles_Shade
Message 3 of 11 (2,184 Views)
07-27-2012 07:18 AM in reply to: madcowscarnival
Small consolation but True View 2013 installed fine here on a Win 7 64bit OS.
Can I convert the file for you?
What version do you need?
BTW - What version of CAD are you on?
Under the File dropdown do you have the option to Convert there? It is built in to LT 2013
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
pendean
Message 4 of 11 (2,167 Views)
07-27-2012 09:51 AM in reply to: madcowscarnival
TRUEVIEW support forum is here:
http://forums.autodesk.com/t5/DWG-TrueView/bd-p/109
Installation forum for most Autodesk products is here:
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
The program may not like the version/variant of .NET4 you have installed: a removal would be something to try if you cannot get help from the two forums above (search for similar problems there too, don't just post).
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
madcowscarnival
Message 5 of 11 (2,159 Views)
07-27-2012 12:39 PM in reply to: Charles_Shade
Thanks for the offer Shade.  The Architect was able to get someone to go to her desk and save as a format that I needed.  I did search the forums for a similar problem to mine, with no applicable results.  I will continue the search and install attempts.
Valued Contributor
Barvas11
Message 6 of 11 (1,887 Views)
same here
11-02-2012 08:01 AM in reply to: madcowscarnival
Exactly the same issue in here! Nothing helps! Rubbish!
Charles_Shade
Message 7 of 11 (1,884 Views)
Re: same here
11-02-2012 08:11 AM in reply to: Barvas11
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Uninstall the Trueview using REVO UNINSTALLER Free on its most aggressive setting.
Then start anew.
madcowscarnival
Message 8 of 11 (1,874 Views)
11-02-2012 09:01 AM in reply to: madcowscarnival
Barvas11, I took the .NET uninstall with REVO and reinstall steps as listed by Shade prior to my original posting, to no success.  Here is what "somehow" worked.  I had been wanting to install the trial version of ACad 2013 anyway.  So after a HUGE download, I went through the install process, and noticed that where I expected it to hang up (in the same manner as TrueView) 2013 took an extra step, added what was needed to the .NET framework, and completed installation.  Since I was paying close attention to the processes and noticed that it did not hang up with the error, I then tried True View again, and it worked properly.  Bizzaro.
So to summarize, install a trial of the newest ACad product and then install True View 2013
Valued Contributor
Barvas11
Message 9 of 11 (1,870 Views)
11-02-2012 09:28 AM in reply to: madcowscarnival
 Hi madcowscarnival,
I just did as they said and it didn't work (no surprise to be honest)
I will try to install new 2013 and see what happens. Can you run two different versions of autocad on the same pc?
madcowscarnival
Message 10 of 11 (1,867 Views)
11-02-2012 09:38 AM in reply to: Barvas11
I had no problem with running multiple versions of Autocad on my machine.  It changed the icon for dwg when I installed 2013, but after uninstall they reverted to the correct icon with no problem.
