Can't find this "request" code. I found an activation code in my email confirmation but it doesn't work. So, I can't finish my registration which means I can't get support. Does this seem backward to anyone else?
Hello Lynne!
Apologies for the inconvenience. Can you provide a screen shot of where the process is asking for a request code? Is it the same request code that's referenced here?
Thanks for confirming and it doesn't look like the image came through. Are you able to generate a request code from the activation screen?
I can certainly help troubleshoot the up and ready registration issue, but just out of curiosity, what is the main issue that you're having getting your software up and running? Installation? Activation? Any specific errors?
Can you please copy the exact error message?
Additionally, can you send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number and the link you received to register for Up and Ready support.
There is one monitor shared by two workstations via a switch. The towers
are not used at the same time so the switch lets me have one monitor on the
desk. The workstation is an older Dell with new hard drive, 8GB memory and
Windows 7; it meets all the hardware requirements for AutoCAD LT 2014 as far
as I can discern. The program launched and functioned fine once as I took a
look around to see how it differs from the 2004 LT that I used on the old
hard drive.
I purchased the software through Amazon, which I now see was a big mistake
as for the first time ever I have AutoCAD issues and support has been hard
to access.
Edited by
Discussion_Admin
The error message said that the problem was with a video driver file that was missing or corrupted. I have uninstalled everything autodesk, including the subkeys in the registry, reinstalled the autocad, and now I am up and running. It appears that my anti-virus was still running the first time around, even though I thought I had disabled it, and that was the thing that corrupted a file or more on the installation.
