Hello
I'm using ACAD LT 2008.
When i try to copy paste some drawing entities from a heavy drawing file to any other file, the program blocks and says 'not responding', endlessly. So i always have to shutdown the program. I experience the same problem using the designcenter: when I try to copy a layout into another drawing, my computer gets stuck.
Another annoying problem with these files is that they are so heavy, while in fact they shouldn't be. I tried the aectoacad file command. In result the file id half as big, but after I open it and save it, again is the original size.
I experience this problem since I entered some entities from other files, other vector programs. The drawings are fully purged.
I am desperate of help!!
j.g.
Hi, have you tried to WBLOCK the drawing after you have done the aectoacad command? Sometimes this will get rid of unwanted "baggage".
Why do you need AECTOACAD? Are these files not created in LT?
Audit?
Purge?
As well as the WBLOCK?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
He is running 2008. Maybe the scalelist is running wild on him.
DJ
Same problem here. Heavy drawings, copy-paste(clips) malfunctions.
We have solved it by:
save as dxf file
close and open the dxf
-purge (notice the minus in front of purge!) > all (in the bottom)> enter > N > enter
audit > Y > enter (takes a while)
purge (no minus this time)
That's how it worked for us
I tried this method, and it did not work for me unfortunately. I am having the same issue as the original poster, but in AutocadLT 2013.
