Show only
Search instead for
I know LT does not support LISP or VBA.
I made a bubble pointer lisp routine a LONG time ago for AutoCAD 2000 full version.
It involved a leader command and a circle and trimming the leader to the circle somehow. And a text command. I don’t remember it exactly because it was 7 years ago. It also kept track of the number in a variable somehow so the next bubble had the next number.
I was wondering if one could stack together macro commands to do this in LT.
Or any other ideas. I am constantly making new drawings with lots of bubble pointers.
I am trying to talk them into Full version of AutoCAD.
No option for the auto-numbering without always resetting it
(to start or continue) separately, but while you wait for
others...
Are you using QLEADER command with the option of dropping a
block in place of text for your bubble/pointer routine? Or
if you have a current version of LT (2007 and higher),
trying out Dynamic Blocks for the task of bubble/leader
block placements? That way you can skip all that trimming
etc.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Here is what I'm doing right now in AutoCAD 2000 LT,
I have a Wblock with a number in it. The number is an attribute so it prompts after the insertion point. I would like to just add the Line command to it at the end.
here is that macro:
^C^C-insert "C:/Program Files/AutoCAD LT 2000/Sample Point.dwg";\;;;_Line
But it puts the Word LINE in the attribute text and does not prompt anymore.
Dean, You wrote
"You need another to finish the block"
Another What?
; semicolon doesn't work
I tried a could of thing I either get the word line in the block or is skips the asking for the attribute in the block altogether.
I'm so close.
